Release Project Tracker 2.3.2 Released
A new update is available for Project Tracker by XenCustomize.
🎯 XenCustomize Project Tracker 2.3.2 Released​
We're pleased to release Project Tracker 2.3.2, a customer-suggestion focused update that improves milestone management from both the Admin CP and the frontend project workflow.
Milestones can now be deleted from the Admin CP with a confirmation overlay. When a milestone has related roadmap items or work logs, you can either reassign them to another milestone in the same project or delete them together with the milestone.
This release also adds frontend milestone editing, allowing permitted users to update milestone details directly from the project view without switching back to the Admin CP. Milestone title, changelog URL, status, progress, and release date can now be managed from the same workflow used for roadmap items and work logs.
A new Edit milestones permission gives you separate control over who can manage milestones from the frontend, keeping milestone editing independent from roadmap item and work log permissions.
Thank you for your continued support and suggestions. If you're enjoying Project Tracker, we'd greatly appreciate a rating on XenForo. ⭐
🆕 New features & improvements​
  • Added Admin CP milestone deletion with an XF-native confirmation overlay, including options to reassign related roadmap items and work logs to another milestone in the same project or delete them with the milestone (Suggested by @Matt C.).
  • Added frontend milestone editing so permitted users can update milestone title, changelog URL, status, progress, and release date directly from the project view without going to the Admin CP (Suggested by @Matt C.).
  • Added a dedicated Edit milestones permission for controlling frontend milestone management separately from roadmap item and work log editing.
  • Added XenCustomize Core Library v1.0.1 (free) as a required dependency.
  • Added license key setup through the add-on options License options tab.
  • Added optional branding-free license key support where applicable.
🐞 Bug fixes​
📝 Notes​
  • Released milestones now use the current time as the release date if no date is entered from the frontend.
  • Frontend milestone edits use the same status-change notification flow as Admin CP edits.
  • The frontend milestone editor focuses on editing milestone details; milestone deletion remains Admin CP only.
  • Milestone deletion protects related roadmap items and work logs from being orphaned.
  • Reassignment is limited to another milestone in the same project, with validation if the selected target is missing or invalid.
  • Deleting related records remains available for cleanup when a milestone and its scoped content are no longer needed.
🔹 Milestone add, edit, delete
🔹 Milestone delete confirm example 1
🔹 Milestone delete confirm example 2
🔹 Milestone delete confirm example 3
🔹 User group permissions - Edit milestones
🔹 Project view - Milestone edit link
🔹 Project view - Milestone edit overlay
XenForo 2.3 XenCustomize Core Library 1.0.1+ PHP 8.0.0+
12 Months
$80.00
$52.00
$75.00
