A new product by XenCustomize is available: Developer Tools 2.0.0 - Streamlined ACP tools for toggling debug and development modes with automated safety resets.
Take control of your development workflow directly from the Admin CP!
Developing for XenForo 2 often requires constant switching between your config.php file and the browser to toggle Debug and Development modes. XenCustomize Developer Tools eliminates this friction, allowing you to manage your environment with a single click while ensuring your production site stays safe.
Built for developers, by developers. Elevate your XenForo workflow today!
Get your copy of Developer Tools 2.0.0 today!
Take control of your development workflow directly from the Admin CP!Developing for XenForo 2 often requires constant switching between your config.php file and the browser to toggle Debug and Development modes. XenCustomize Developer Tools eliminates this friction, allowing you to manage your environment with a single click while ensuring your production site stays safe.
Seamless Mode Toggling – Instantly enable or disable XenForo Debug Mode and Development Mode via the Admin CP options.
Safety Auto-Disable – Forget to turn off debug mode? No problem! An automated Cron job runs 4 times daily to ensure these modes are toggled OFF, preventing accidental exposure on live sites.
Permission-Based Access – Security first! Only administrators with specific permissions can see debug output or access development features, keeping your data safe from other staff members.
Default Add-on ID Mapping – Speed up your coding! Define a default Add-on ID so that every new phrase, template, or permission you create is automatically assigned to your current project.
Error Reporting – Automatically forces display_errors to "On" when either mode is active, making it easier to catch bugs in real-time.
Developer-Centric Benefits
- Optimized Performance: Built with XF 2.3 standards using high-performance listeners and optimized repository calls.
- CLI Friendly: Robust code logic ensures no conflicts with command-line operations or system upgrades.
Installation
- Upload the contents of the upload folder to your XenForo root.
- Install the add-on from the ACP.
- Configure permissions under Groups & permissions > Administrator permissions.
- Navigate to Setup > Options > XenCustomize Developer Tools to begin!
