Release Auto Lock Threads 2.0.0 Released
A new product by XenCustomize is available: Auto Lock Threads 2.0.0.
🔒 XenCustomize Auto Lock Threads for XenForo 2!​
Keep your forum clean, organized, and under control — automatically.
Auto Lock Threads lets you close discussions exactly when you want, without manual moderation.
Set smart rules per thread or apply global rules to entire forums.
Once configured, the addon works silently in the background and locks threads at the right time — every time.
From reply limits to inactivity, specific dates, or thread age, you’re always in full control.
⭐ Key Features​
  • 🔢 Lock after X replies
  • ⏰ Lock at a specific date & time
  • 💤 Lock after post inactivity
  • 📆 Lock after thread age (since creation)
  • 🎯 Per-thread rules via Thread Tools menu
  • 🌍 Global auto-lock rules for selected forums
  • 🔐 Permission-based access (moderators only)
  • 🧠 Smart rule priority (per-thread overrides global)
  • 📝 Moderator log entries for every auto-lock action
  • 🚀 High-performance cron job handling
📋 Complete Features List​
  • Per-thread auto-lock rules
    Set auto-lock rules directly from the Thread Tools menu using a clean overlay interface.
  • Single active rule per thread
    Only one rule can be active at a time to avoid conflicts and keep behavior predictable.
  • Four powerful rule types
    • Lock after a maximum reply count
    • Lock at a specific date & time
    • Lock after post inactivity (time since last reply)
    • Lock after thread age (time since creation)
  • Visual lock indicators
    A clear and attractive info bar on the thread view shows when and why the thread will be locked.
  • Permission-based control
    Control who can manage auto-lock rules using a dedicated permission:
    Forum moderator permission → “Set auto-lock rules for threads”
  • Automatic lock execution
    Threads are locked automatically via:
    • Thread view checks
    • New reply submissions
    • Background cron job
  • Global auto-lock rules (Admin controlled)
    Define default auto-lock behavior for selected forums using admin options.
  • Global rule types
    • Disabled (by default)
    • Lock after maximum replies
  • Applicable forums selector
    Choose exactly which forums the global auto-lock rules apply to.
    If no forum is selected, global rules are not applied anywhere.
  • Global rule settings
    • Lock after reply count (number of replies)
    • Lock after inactivity (seconds)
    • Lock after thread age (seconds since creation)
  • Smart rule prioritization
    Thread-specific rules always override global rules for maximum flexibility.
  • Native moderator logs
    Every automatic lock action is logged in the Moderator Log with a clear reason
    (example: Locked due to inactivity).
  • Cron-powered engine
    Reliable background processing ensures timely locking without affecting performance.
  • XenForo-native & safe
    • Fully compatible with XenForo 2.3
    • Uses XenForo permissions, logging, and cron systems
🎯 Ideal Use Cases​
  • Close support threads after a fixed time
  • Stop necroposting automatically
  • Limit heated discussions by reply count
  • Lock event, sale, or announcement threads on a deadline
  • Keep old content readable but no longer replyable
  • Reduce moderator workload with automation
If you manage an active forum, this addon saves time and keeps discussions tidy — automatically.
🖼️ Screenshots​
🔹 Thread Tools → “Set Auto-Lock Rules” link
🔹 Auto-Lock Rules overlay (all rule options visible)
🔹 Thread info bar showing scheduled lock message
🔹 Admin options: Global auto-lock settings
🔹 Moderator log entry for auto-locked thread
🔹 User group permission
🔹 Cron entry
